lw395
I am struggling to think of a situation where VMG to waypoint would be useful.
Upwind (within the laylines) VMG to wind is correct, and VMG to waypoint incorrect unless you set a waypoint upwind of you at an arbitrarily large distance. The same is true downwind (largest negative VMG to wind).
On a reach it might be that luffing or bearing away from the straight line would increase your closing speed, but then you would end up sailing in a curve, which must be slower than a constant heading?
So what am I missing?
I think it's pretty over rated.
But if you don't trust the wind instruments to be accurate enough, or want to use an average or predicted wind direction instead of the instantaneous it could be useful.
I suppose you could dream up uses for it when sailing in lots of current too?
