It's actually a spare I nabbed of a ship !! You can get them direct from McMurdo ... it uses D cell batterys and has a mercury switch inside ... standard torch bulb etc.
Hangs upside down in a spring clip (x2) and has lasted years .... just change batterys annually or more if necessary .... Make sure you use sealed metal case type ...
The only opening is the lens and bulb holder .... remove to access batterys ... no other caps or openings ...
Not cheap I bet - but reliable and long-lasting ....
In northern cold waters ... Hypo can kill in a matter of a few minutes ... especially if MOB person starts to swim towards a marker !! Sounds stupid but true.
Re: Hypothermia ... kills quicker than you think !
sorry to be so morbid ...
True - but equally you can get unexpectedly long survival times in such cases too. I personally know of one who survived close to two hours (with NO outdoor gear at all) in a temperature of 7.8 C - no life jacket either.
Just an observation - Danbouys are not a RORC requirement these days for races of lesser severity than the Fastnet, Sydney Hobart, Cascais etc. (when did you last see a new race boat with the tunnels in the transom? Late '80s? What the RORC does require is a strobe on the lifejacket, and another attached to the ring - I'd give my vote to the newest Ocean Safety strobe - it's one of the few that has consistently worked when I upend it.
Sprayhoods definitely work - a very significant number of casualties drown whilst wearing a lifejacket from spray and spume.
In tests carried out by the Norwegian Maritime Directorate...
...(who have a serious interest in cold water survival, to say the least) a few years ago, volunteers who jumped in to cold waters wearing two black plastic bin liners lasted as long, before serious cold symptoms set in, as volunteers wearing IMO approved immersion suits!
So, if you can't run to dry suits for all on board, ( a new IMO requirement for bulk carriers, incidentally) - carry some bin liners!
My objection to theCrewsaver spray hood is that it is not at all easy to fit when one is already in cold water (and probably panicking and hyperventilating!) I am not in any sense arguing that spray hoods are not necessary. I want Crewsaver, a very fine firm, imho, to design a better one, preferably integral with the jacket and harness.
Re: In tests carried out by the Norwegian Maritime Directorate...
Totally agree about the Crewsaver hoods. They should come as standard and be properly fixed, not an optional fiddly extra.
The time when you are most likely to swallow water is during the first minute of immersion, during which time you are going through cold shock and breathlessness. The chances of calmly getting the hood out of its pouch and fitting it are close to zero.
I bought one recently and have binned the pouch and fitted it inside my lifejacket. This was after trying it in the comfort of my lounge where it still took ages to open the thing out - akin to trying to reuse clingfilm.
