Poecheng
Why not use what is left in the batteries to power an inverter to power a modern battery charger. Charge the batteries up in no time:encouragement:
I need power but don't have space for a generator. It would be easy to permanently install an alternator in some corner. Could one munge a strimmer so that its motor had a short splined shaft to plug into an alternator through a hole in the side of the cockpit (rather like a blender thingy)? Would the power and rpm match? I could easily stow a strimmer motor with a bit of a prong of shaft. I'd like to be able to create a charge of about 30 amps.
I don't really think this is a serious question - unless someone fairly expert says it's OK and easy!
I'll pee to leeward in future. The correct solution is to replace the concrete mixer in my saloon with a civilised engine that can also generate power. Trouble is, it'd cost about 80% of the current value of the boat and perhaps increase its value by about 2%. Could sell the boat to pay for it.I would say you are peeing in the wind and you will be wasting your time and efforts. The cutting in voltage of the alternator will damn near stall the engine, an alternator from a car does not have a soft start and it will by nature of the beast want to charge higher at low revs once the rotor is energised. I think your work with the effort and cost that you will have to apply will be at a total loss. I'm sure if you have room for such a set up you have room for a suitcase generator which imho is the way to go.
My engine is no longer made, but it's like this http://farymann.de/en/showpdf.aspx?Seite=Engines&Datei=Farymann_18_W_YRS&en=1. There ain't any way to attach a pulley.
Wouldn't it make a lot less noise if you used a battery powered strimmer?
How about an alternator off the prop shaft?My engine is no longer made, but it's like this http://farymann.de/en/showpdf.aspx?Seite=Engines&Datei=Farymann_18_W_YRS&en=1. There ain't any way to attach a pulley.
Someone ran a thread here a year or so ago about making a genset from a small Honda industrial engine. I seem to remember it was quite successful.
The flywheel is between the engine and the gearbox and is totally encased. Major surgery would be necessary, with no guarantee of success.A pully can be made and bolted to the flywheel.That's how I'd solve the problem.
Many years ago Amulet did have such an arrangement. Problems: (a) an alternator has to spin one helluva lot faster than the prop to generate power, and (b) you can't run the engine in neutral to generate power.How about an alternator off the prop shaft?
It exists: thesupercharger.co.uk
Put the suitcase genny in the tender and have a long extension lead. :0)What a flurry of fun. Nothing makes me inclined to pursue the idea. My motivation - saving space is the primary goal. I managed a fridge in my tiny boat because the compressor could be squeezed behind the loo and plumbed to the chamber. Now... I can't easily fit a suitcase generator anywhere. I could build an alternator into unused space, say behind the cockpit seats. The petrol motor needs to be above deck in use. I was looking for a solution which enabled me to move only the motor - to lift it out and attach it to drive a buried system through a hole in the wall.
Insane.
