stevebrassett
The main problem with my outboard is that I can turn it and spin my boat around on a sixpense. It stops me having hours of fun doing 9-point turns in the marina.
What's a sixpence?The main problem with my outboard is that I can turn it and spin my boat around on a sixpense. It stops me having hours of fun doing 9-point turns in the marina.
What's a sixpense?
I should tell you my sorry tale of woe with my outboard main engine. It's a Yamaha 9.9, 12 years old now. It propels me at 5.5 knots consuming a gallon of fuel every 22 miles. Even though I replace the oil and filter every year and the impellor and plugs every few years, many years back I had to replace the fuel pump membrane for £18 as well. I was gutted. This is the sort of palava and expense you can expect with your Tohatsu over the next decade or two.
You failed to mention their meoldic tooth sucking as they judge how much the job will cost by looking at the quality of your car
Surely you were OK on that front, though?
The OP (according to his first post) is thinking of buying a Mk1 Crabber which has a 1GM, hence his question - not for his current Anderson 22 (Seajet would not permit that, the Anderson is only for "real" sailors!).
Surprised it cost £9k to fit a new piston and liner, who quoted you that ?I can do better than 11k; my other boat, a 1950's estuary cruiser had a 62hp 5 cyl Nanni installed in 2003. When in 2008 the front piston came adrift and gauged three large scores in the bore making it an uneconomic repair, Peachments only interest was to sell me another 62hp Nanni. Total cost, plus most of a season lost, about 18k. Hence my reluctance to ever have a Nanni again.
No liners of those engines. And not much metal between the cylinder bores.
Why are you thinking of a replacement? is the original engine shot..or are you just looking for something with a bit more ooomph?
If the engine is shot then it will probably cheaper to replace like-for-like if possible , albeit 2nd hand if available, engine mounts, transmission, fuel lines etc can remain....
I hear on the grapevine that it now has both forwards and reverse gears
D
I spent £300 on another used engine from ebay and fitted it myself in a (long) weekend.
If I have any trouble with the boat Yanmar, (OK, exhaust elbow & water pump replaced in 2009) I don't think I'll be buying a new Beta for SillyMoney.
As the YoofOfToday would have it: "Just saying, like"![]()
same for an ouboard ?? They can be complete s@ds sometimes.....
Mine was a complete sod to start once. Kept on pressing the red button and it just refused to go. After an extensive engineering investigation by a trained qualified engineer, it was discovered that the battery main circuit breaker was in the off position.
£500 well spent, eh ?
Boo2
Good article in November yachting monthy. £6400 paided for Beta30, boat show special i think. Chap replaced everythink , total cost£10394. Cost included engine fitting. Well worth a read.
I replace a GM1 with a nanni 14.... I had some mounting plates made which raised the hight and moved the feet centres to the correct position.
The fitting time was about 4 hours to remove the old and bolt in the new.
