msjston
What kind of figure should I be looking for from a boatyard to get a full gel peel and 4 or 5 layers of preventative epoxy coats on a 34' hull with a fin keel? Thanks for any advice...
I would not recommend peeling your gelcoat - itś been proven too many times to be a useless process no matter what is wrong with your boat. IF you have osmosis (?) and the gelcoat needs removing then only sand blasting will work.
hi there
Ive just completed this project during the last 2 summers
done all the work myself.... so I probably saved aprrox £3000 in labour costs
I had osmosis blisters all over the hull, about the size of you finger nail
so in brief;-
My 36 ft hull was sand blasted 2 seasons ago by my boat yard
cost less than £800
I let her dry out over 2 seasons, but this may not be the case for you,
applied 2 coats of epoxy filler( 4 x 5 litre tins) and 5 coats of epoxy paint (12 x 5 litre tins)
cost approx £1500
hope this helps
Hi,
For sure peeling will remove the gelcoat back to the lamination. However the nature by which the machine peels off the gelcoat is not suited to osmosis treatment - more importantly the drying of the lamination. As you peel off you effectively re-seal something like 50 % of the lamination again, trapping residuals and moisture which overall will take much longer to dry. Also, another important factor is surface area. You create much more surface area by sand blasting which firstly makes drying and cleaning out the lamination more effective (getting into softer areas is easy) and secondly it creates the correct surface for accepting the new filler/ bonding of the epoxy lamination / or filler depending how bad the blisters are. Peeling however is bad in both respects here.
Over the years Ive seen different jobs come back with blisters re-appearing and in all cases these hulls were peeled (not by me). However sand blasting always works if the job is done properly.
Normally a mobile blaster with diesel genny and tenting material and all the breathing kit etc charges more than if you get it done "in house" of course which is better.
hi there
so in brief;-
cost less than £800
cost approx £1500
hope this helps
I would not recommend peeling your gelcoat - itś been proven too many times to be a useless process no matter what is wrong with your boat. IF you have osmosis (?) and the gelcoat needs removing then only sand blasting will work. It needs to be an experienced sand blaster and they charge per m2. Normally for 34 ft the price will be around 2K.
If your boat has not got osmosis and you just want to protect it, then just sand it back to the original gelcoat and when itś as dry as you can get it then epoxy prime it with West Sytem or similar (with aluminium additive in the resin).
Hi,
correct, except for the last sentence - this is why you peel then (light) blast. It leaves a surface which is far more fair and this cheaper and easier to rebuild.
Is it easy to get a good finish on DIY application of epoxy filler and paint? I'd rather do this myself too if its not necessarily a specialist job.
