Lon nan Gruagach
Corrosion is the oxidisation of metal, in steel and iron this is rust, others dont have specific names.
Steel/iron is a significant problem since oxides of most other metals provide a protective surface, but iron does not and the corrosion continues until nothing is left.
Corrosion is an electro chemical process which can be prevented by several means including cathodic protection.
Cathodic protection works by preventing or very quickly reversing the occurrence of anodic areas on the structure. Achieved by providing a source of electrons either from a voltage source or a sacrificial anode.
When 2 dissimilar metals are immersed in an electrolyte and are electrically bonded they will most likely form an anode, cathode pair depending on their relative reactivity to the electrolyte. Despite any protective oxidisation that might occur the anode will corrode faster than normal while the cathode will corrode slower or not at all (until the anode is all gone that is).
So, why and when to fit anodes:
When the metal will corrode due to simple oxidisation or being part of a bonded anode cathode pair.
What anode to fit:
One that is more reactive to the electrolyte than the most reactive metal that you wish to protect.
What was I missing?
A bad case of old wives tales built up in world that thinks it knows it all.
Why post?
didnt want to continue a thread drifting spat.
Top tip, when you insult someone by saying read what you just linked to, have a read of it yourself.
What anode to fit:
What was I missing?
Why post?
