dom
An MPPT controller is not the best choice with a single panel. Not all controllers require a 5v differential. 2.5mm cable, up to about 5m to the controller is correct for a 100w panel.
Of course he won't. I advised 6mm from controller to the batteries, if he fits enough panels so that 6mm is under spec the controller will be overloaded. If he fits another panel in parallel that panel will be wired to the controller directly, it will not require the existing wiring to be altered in any way. If, on the other hand, he fits a second panel and wires it in series with the existing panel the 2.5mm cable will still be as adequate as it is now.
In short, 2.5mm cable from the panel to the controller, max length 5m. 6mm cable from controller to batteries. Job done.
Do you know the controller make, for the OP didn't say? A slightly heavier gauge cable has got to be a heck of a lot cheaper than a new controller! Re your parallel point; there is most certainly no need to run a separate cable to the controller. Either way OP can now make his mind up so please excuse me if this little matter is getting needlessly heated.
