Franknstein
Active Member
Hi
I have a 23ft maxum, which came with a double axle trailer. Entire rig is probably over 3 tonnes, not sure exactly, but its fairly heavy.
Anyhow, It came with an indespension jockey wheel attached I'd say perhaps 2m forward of half-way of the trailer. Seems its been in that position a while though, perhaps even when the trailer was built.
Now, the wheel axle collapsed when launching the boat in the spring, and has now I suspect bent the shaft or mechanism internally as it no longer wants to wind up or down.
My thinking is its mounted too far back, and should in fact be right up at the front on the tongue.... As it would have less weight to lift at that location. But I don't know enough about it to say that that is the case, perhaps its further back for a specific reason I've overlooked. Can anyone tell me if moving it way more forward is a good move?
Also looking for a jockey wheel that wont break, bend, have tyres delaminate or burst (I constantly have jockey wheel problems for some reason, they all seem to be rubbish). So perhaps someone could recommend a good jockey for my setup, that can also cope with trailer launching at the ramp with long rope etc and using the jockey as a third wheel to pull up and down the ramp.
Any thoughts most welcome.
