IsmoS
New Member
Hi all,
good tips are now valuable.
Corniche with 2xTAMD 41A shafts (Ex. VolvoPaul, "Ceres").
Starboard side vibrate a lot when fast run. 3000...3800 rpm (18...26knots).
750...1700rpm / 4...7,5 knots no vibration noticeable. Also no vibrate with neutral gear and high revs.
Vibaration was and is so hard that engine mounts was broken up and axel bearings loose. Vibration feels all over the boat and is like wavy. Increasing and decreacing all the time. Port side run is smooth.
Propellers are renovated and balanced by professional.
Shafts are ok. Checked with lathe by professional.
New shafts bearings.
New Flexible Coupling (A.S.A.P Supplies, part nro 807109)
New gearbox (MS4A) oil , no pieces of metal founded. Gears works fine.
Shaft and gearbox is in line. Less than 0,05mm.
New engine mounts.
Nozzles are chekked. "No as good as they can be but good enought" (sayed by diesel engineer). Opening pressures was all the same (12 pieces).
All filters are new.
Fuel lines are ok by visualy and leaks not founded.
Still vibrate alot... can not understand anymore. Need help, please.
Could the problem be in the fuel supply? Feed pump timing or transfer pump?
What happen if feed pump timing not work as it shoult work?
Or if transfer pump do not produce sufficient pressure or volume.
Or something else?
Any ideas or experience?
Thx for any advance.
Ismo
New engine mounts.
Or something else?
Ismo
