Corian or similar worktop? Where do I buy it?
john_morris_uk
3 Jul 2002
At sea somewhere.
I am having difficulty in sourcing some Corian or similar work-top. I need a couple of bits for the galley of the boat and it seems that there is a cartel system in place in which only authorised fitters can buy the stuff and fit it to your kitchen? Obviously, our boat doesn't count - and in addition to which I don't want the resin based material mounted on a sub strata of Mdf or chipboard if its to go in our boat!!! I want a bit that I can glue to marine ply and not worry about the substrata swelling up in the marine environment.
Today we did a quick tour of the DIY stores and after Wickes and Homebase (nil point - they don't do anything suitable) we found B&Q where they have a range of 'suitable' work-tops' which are not Corian, but are their own make I guess. The only trouble is that they are only available to those who have kitchens designed by them - and certainly not to oiks like me who want a bit for their boat's galley. The man almost seemed pleased to tell me that it was not available to me to buy for a boat...
Any idea where I can source some Corian or similar style work top?
Had similar problems trying to source corian type product when fitting out the galley. Actually ended up using a sheet of granite style heat resistant fire surround, which was then available in both of the sheds....about 4mm thick & glued nicely onto marine ply..HTH
Corian can be obtained fron kitchen fitters. They often have excess material left over from kitchen fitting. It is very expensive around £350.00 for a sheet 750mm x 3000mm.
Another source is from sign makers who use it. Google corian signs and you will find someone.
corian or similar
john
pm me your phone number- i am in the kitchen business and can help with a couple of options. based in sidmouth, so local to.
alteratively visit our web site for contact details www.4homes.ltd.uk - if you phone ask for mike
What sizes do you need and what type of corian ? I know a few approved fitters that may have some offcuts they are willing to sell . It is kept in the trade by Corian and approved fitters have to pay to do the course on how to fit it . Nothing to do with the fitters at all , more to do with the pen pushers .
Here is a tip for fitting a laminate in an enclosed space to a predetermined akward shape:~
Cut thin strips of thin material the thickness of veneer or even scraps of laminate about 1" wide.
Then lay these so the ends overlap and for the outside edges to exactly replicate the perimeter.
Then apply glue to each overlapping corner and set down to make a perfect template.
Allow glue to harden and lift off.
Then lay this template over a sheet of laminate and with a fine pencil mark off clearly all the way round.
Cut with a sharp edged tool (like for example a sailmaker's needle) by repeatedly scribing (scratching) on the outside side of the pencil lines using a metal ruler.
When the groove is deep enough, snap off.
When you have the result, now trial fit.
To fit it perfectly use a wet or dry paper on a block to run along the edges back and forth to remove burrs until the fit is perfect.
Now take three thin sticks of wood about 1/4" by say 1/2" section slightly longer than either the width or the length of the surface.
Apply contact adhesive to both surfaces and allow them to become touch dry.
Lay the strips across the surface to be covered at equally spaced intervals.
Now lay on top the surface to be fitted.
Position it accurately.
Remove the strips one by one by pulling gently from under and the surface and laminate edges will cooincide exactly. Press by applying pressure with a crumpled cloth in a hard ball in circular movements spiralling outwards to remove any air bubbles that may be trapped.
Now light a Havana Cigar and tap yourself with your right hand on your left shoulder and say to yourself "Well Done!".
Gloating is permitted.
Now Enjoy !...:D
