PabloPicasso
A core plug ( also I believe called freeze or Welch plugs) on my engine is weeping and needs replacing. Should a gasket type sealant be used when putting in a replacement?
Yes, but not gasket sealant. Use a dedicated core plug sealant such as the loctite oneA core plug ( also I believe called freeze or Welch plugs) on my engine is weeping and needs replacing. Should a gasket type sealant be used when putting in a replacement?
www.solocoastalsailing.co.uk
AFAIK, two types of core plug used. One, slightly dished, tapered edge, placed into hole and the whacked in the centre to expand the edge into the matching machined taper in the block.
Little chance of ANY sealant working for long with this type.
The more modern sort with a right angle edge about 20% of the diameter. Sealant will work here.
With both types, scrupulous cleanliness when preparing the hole is paramount.
Although a core plug might be pushed out should the engine freeze and perhaps limit damage to the water jacket, they are only there as a requirement of the casting process during making the block/head.
It allows the sand core to be removed after casting, hence the name " Core plug. "
"Freeze plug", totally irelevent.
Is that an epoxy mix, not a sealant as such
As it is awkward to get at, would sealing over the weeping rim with liquid metal be a good option? Assuming it can be dry and clean of course.
From the Loctite technical data sheetLOCTITE® 540™ is a thixotropic anaerobic sealant designed
for sealing core plugs and many other high strength sealing
applications where non-migration is desired. This product is
easily applied with LOCTITE® applicators and prevents rusting
in the threaded engagement area. Applications include sealing
and securing cylindrical metal assemblies, e.g. engine block
cup and core plugs, water pump seals, and hub and shaft
assemblies. The thixotropic nature of LOCTITE® 540™
reduces the migration of liquid product after application to the
substrate.
