Cordless water pump.
lydiamight
9 Feb 2004
North West Kent
Having a Dehler 36CWS without a bilge sump it's always a pain going round the various sections of the bilges getting out bilge water (yes I know I shouldn't have any leaks but I've got a minor drip from the rear of the engine and some weeping pipework on the cold water supply both of which won't be sorted out until the winter) Does anyone know of a hand held cordless electric water pump that I cold use?
bruce
26 May 2004
florida USA
ATTWOOD MAKES a d cell powered refered to as 'water buster' comes with 42" attached hose and rated for 200 gph. should be available over there. can see in 'westmarine.com' catalog. about $36.00.
DavidGrieves
13 Aug 2001
West Cumbria, Cumbria
www.wsandba.co.uk
bruce
26 May 2004
florida USA
have one of those, req both hands, one to hold drill motor and other to keep pump from spinning. pump works, but not fun to use/untangle afterwords plus the mess from what ever being pumped being thrown out while pump spins
TrueBlue
30 Apr 2004
Sussex
Not what you asked for, but:-
1). Cheapo manual sump pump, about a tenner; quite useful in removing water in restricted areas. Available from Swindleries specialising in small boats.
2). Manual bilge pump as mentioned in other posts. From ASAP
3). (Nearest your request). Super_Sub (?) made by those mice Whale people, don't consume much power at 12V so you could make up an extension lead from your battery, or get one of those rechargeable megatorch jobbies this from Farnell /CPC / Maplin etc, pump from ASAP.
Truly cordless unit is likely to eat batteries / be bulky.
Others may know better
Have used all three in different situations.
Stop what you're doing and wait my signal
TonyS
23 Feb 2003
Southampton, UK
I have used a cordless vacuum cleaner. It is one that is meant for liquids as well as dust and with the small pipe extension provided it will pull out small quantities. If more water than the holder will take it has to be done a few times emptying each time. It stays on board and is used to clean the floor and upholstery. It has a 12 volt lead and is also rechargeable from the mains.
<hr width=100% size=1>Tony
Use a foot pump
The inflatable air pump in deflate mode will suck up water and being plastic will not corrode .... (newer ones that is)
Other idea is an old trick with the loo ..... get a rubber bung suitable sized to fit the bowl, cut hole through centre and fit suitable tube of length to reach bilge areas ..... now fit bung to bowl, pipe into corners etc and pump loo ..... the suction when bung fitted correctly is immense and clears everything ....
This was highlighted as an emergency pump system in PBO many years ago .... and I think is in the handbooks.
<hr width=100% size=1>Nigel ... and of course Yahoo groups :
http://groups.yahoo.com/group/gps-navigator/
bruce
26 May 2004
florida USA
for very small areas, a plastic kitchen baster as used in cooking will reach small areas and suck up small amounts of water.
