geem
It's identical enough in content to what I got 18 months ago that I'd be 95% certain I know which yard. I think the "4 week package" covers haul out and haul in, although storage ashore for the proposed duration of the operation seemed to be covered by a separate 4-figure line item. I say "proposed" because a friend had his boat done there and their project management skills seemed to be out of the 1970s British workers' playbook with things overrunning by many months.
My quotes (last year) were in the (roughly) £9-10k inc range for a 12m boat for a complete package of lifting, mast take down, stripping old antifoul, re-epoxying and full anti-osmosis if necessary, coppercoating and relaunch and re-rigging. Check quotes carefully because they may not all be for the same thing, specifically number of coats (epoxy/coppercoat) and method of application. The coppercoating itself only seems to be about a quarter of the overall cost.
The quote I was most happy with content-wise (ie professionally put together, clear line items, options to "worst-case" and 6/7 sprayed coats of coppercoat) was from Deacons who were highly recommended by coppercoat and who have a manager who, in my previous experience, runs the yard professionally (and are conveniently located next to bursledon train station). It was also the most expensive but I trusted it more.
After weighing up a lot of factors I decided to stick to conventional antifouling for now
That is a crazy price! I can see why you stayed with conventional antifouling. As Vic has suggested, its not technically hard to do. You could have the hull and keel sandblasted and the rest is easily within normal DIY expertise. We did ours a year ago and its great. I think a good time to convert over to CC is when your conventional antifouling needs removing due to a rough flaky build up. It easier to get is blasted. At this point you are no worse off going for CC as you would likely have had it blasted anyway. The epoxy barrier layer is a good investment whether you go for CC or not so the only real on cost at that point is the cost of the CC. Over here in the Caribbean antifouling paint is super expensive. A couple of layers of good antifouling paint is only a little cheaper than an application of five coats of CC. Its a no brainer here
