kalindi
I went to the boat on Sunday to check if everything was ok after the recent bad weather and noticed that the copper kettle I have had completely changed colour to a uniform gunmetal apprearance. This surface is qite hard and cannot be washed off. On close inspection an oil burning lamp had also changed colour but only in directly exposed areas but generally of a simmillar experience. Everything else seems ok. The only thing that I could think off was that the batteries had over charged and vented gas into the saloon in sufficient quantities to cause this problem but on examiningthe battery bank everything seemed to be OK. So I hope someone can help me understand what has happened. As you can imagine I am a bit worried about what chemicals I have got circulating in the atmosphere. By the way the boat is reasonably ventilated by leaving vents open and has a small solar powered fan running when the sun shines, we are based in southern france, but it is also damp due to the specially bad weather we have at the moment and some leaks still to be fixed.
Thanks in anticipation of the help
