snowleopard
Finally tracked down a leak in my fuel line. The engine had been losing revs and needed bleeding regularly, plus a strong smell of fuel in the cabin. It turned out to be a pinhole leak in the copper pipe which I found after scraping off a layer of green goo.
The pipe is 8mm plumber's copper pipe. What is likely to be the culprit and what should I do to protect the new pipe from a recurrence?
