SvenglishTommy
I was replacing the primary fuel filter last week, and decided that while I was at I would replace the rather dodgy looking unmarked old fuel lines and the fuel cock at the tank(which had a slight leak) while I was at it.
I discovered that the dodgy looking fuel lines were actually solid copper pipe covered ina protective sheath. Despite an extensive search I can find very little info on solid copper fuel lines, and inparticular what kind of connections to use.
I eventually ended up at a gas shop who had all the right size connections and compression fittings (including a mini ball valve to replace the fuel cock). They would not commit to it's suitability for use with diesel though, but they couldn't see a problem with it.
What is the panels opinion on keeping the copper fuel lines, and the use of fittings designed for gas with diesel?
Thanks,
Tommy
Thanks,
Tommy
