Portofino
Guessing when stopped water drains out of the bronze pump case or at least the pressure on its side drops to near zero .It needs to never exceed the oil inside pressure .
If left over time the Dir of travel of fluids is oil from the crank case out .......all good .
How ever if you empty to crank case oil during a change that +ve pressure is lost .Ok for a few mins while it’s topped up / refilled .
Then reflect a mo at the first start .......if the water pump self primed ready for off pressure beats the oil pump pressure wise momentarily or longer it may over stress that seal and form a continuity in the wrong direction.
Marcs valve gear again may be better designed in theory with a self prime system with looses its ability to self prime after the pump pick up / sump is drained .
Dont know .
What I do know is ours ( MAN ) the oil seeps back into the sump after shutdown wirh no priming .
So for a moment the top end can be dry before the oil circulates .You know the whole cold start thing waiting for the oil to warm and fully circulate etc .
I did remove a valve cap after 6/8 weeks without running and it was still wet in there .
How ever once after 3 months they were pretty dry .
That why I regularly start n run mine in the winter .....to circulate oil and refresh seals etc .
In theory all things being equal the MTU should out last MAN .In practice there’s far too many variables to make any meaningful distinction s in CAT , D12 Cummins etc . You have to judge each case on it’s individual merits and instal etc
Its all about history and prevention maintenance wise .
Dont know .
