Trundlebug
Get one that fits in the available space!
J
+1 Sounds obvious but work on the principle that you can never have too much hot water.
If weight isn't an issue (it isn't on a displacement boat) go for the biggest calorifier you can fit.
It won't affect the time it takes to have some hot water available initially - (as long as the hw take-off is at the top) and the longer you run the more you'll heat up.
The reason is, a well insulated calorifier will keep the water warm for 36-48 hours, so it extends your cruising options and comfort. If you need lots of hot water, you have it. If you want to conserve it and stay longer, you can. If you have several people staying on board, you'll always need lots of hot water. Not just for washing (showers etc) but washing up and everything else.
As it's free heat, there's no reason not to have as big a tank as you can.
Your only choice then becomes, vertical or horizontal calorifier.
The coils on vertical calorifiers are easier to bleed (self bleeding) whereas the coils on horiz tanks require a big push (more than the engine water pump can manage) to bleed the air out initially when you first plumb it in. Thereafter no problems.
