superheat6k
Following advice on threads and apparently as suggested by Espar in the US, I have converted my Eberspacher D4 to kerosene (aka Paraffin). Simple job, and should keep the thing from coking up.
I understand at high load the D4 burns around 0.25 litres /hr, so the 5 litre fuel container I have used should burn for around 20 hours, easily enough to cover a weekend's intermittent use.
Used some 10mm OD braided clear tube, with a 5mm ID which slipped straight over the ticky pump inlet, then routed this to the fuel container, via a snug hole drilled in the filler cap, with a tiny notch to allow air in as fuel is drawn off.
Priming took several fault resets, and it would be useful if Eber had a priming mode to allow the pump to draw the air up on first use or from an empty tank. Any tips for this - kerosene doesn't taste that nice. Don't ask how I know this !
Once I got it primed it ran beautifully, and I am sure it was quieter than before. I have kept the original diesel supply plugged off nearby so if I run out of kerosene I can easily put it back on diesel.
