William_H
Am I too late? 27mhz antenna come in 2 types. The ones designed for boats have a coil inside to load the antenna so it looks like it has a groundplane. Typically white fibreglass with a cable going into the side of the f/g tube or a coax connector on the side. There is no place to earth the antenna being made for f/g boats. This type have f/g rod inside with wire wrapped around it and a coil and adjusting capacitor.
To convert this type cut the outer tube near the base and remove the outer tube. Make a coaxial antenna. 17.7 inches of centre conductor with screen removed. The screen is folded back to make a 17.7 inch screen over the outer insulation of the coax. Both lengths are critical. Push this 35inch antenna up as far as poss into the f/g tube with the cable emerging at the bottom. Epoxy the tube back onto the base.
The other kind of 27mhz antenna like I use is just a whip with a metal base (usually black). The wire conductor radiator is wrapped around the f/g rod and all covered in heat shrink or similar. This type is made for a car and requires the coax outer to be connected to a large metal body. (ie mast) The centre of the coax only connects to the base. the antenna has a large chrome plated nut at the base of the rod to screw onto the separate base. ($18 at Dick Smith)
If this latter type is yours then strip all the coiled wire off the f/g rod and replace with a straight wire (or no more than 1 turn) up the rod. The lenght should be 17.7 inches or you could go for 3/4 wave length 53.1inches long. then cover again with heat shrink. A section of coax outer is often used as the conductor. Which brings us to the point that you should be able to buy from DS a VHF antenna of this type for less than $18 but it may still have to be trimmed to correct length. (and seal the cut)
My guess is that it is the former type that you have mounted on a f/g deck. Yes of course you can buy a new antenna. Are you not going to keep the 27mhz radio as well? There is not much sign of getting rid of 27mhz here in Perth. PM me if you don't understand as 27mhz story is not of much use to UK types. ....... olewill
