Continue 200 gallons aluminium diesel tank repair idea to put a few small new tanks inside the big old tank.
Status
Not open for further replies.
This time with pictures.
The idea is to put a few small new tanks inside the big tank rather than repair the big old tank.
The old tank is under the bathroom floor. The size LxWxH is 220cm x 90cm x 35cm. Too big to remove!
So I am thinking to cut a rectangle whole on the floor under the TV storage place. It will be 80cm x 50cm. Then cut another rectangle whole on top of the tank around 70cm x 40cm. Then thinking to remove the baffle plates inside the tank to make it empty. But that will be a challenge as I don't know how strong the baffle plates will be.
Do you think this is a good idea or bad? Thanks.
The tank is very long compared to its height and width. The new hole that you want to make in the tank, will it be in the center? Otherwise it might be difficult to access one end
Status
