Contact adhesive solvent
ghostlymoron
9 Apr 2005
Shropshire
I needed to remove some ancient contact adhesive from wood the other day and found that acetone on a rag was best. White spirit had no noticeable effect, likewise meths.
Could be useful.
Top tip, do not try to remove contact adhesive from vinyl headlinings with acetone as it will remove the surface colouring faster than you can blink.
WD40 will remove glue from headlinings with no damage!
So what does it contain? The manufacturer says "less than 25% is mineral oil and the rest is similar, but not exactly the same as Stoddard Solvent, which is a brand of American white spirit. As white spirit formulation varies around the world, it would appear to be more than 50% what we call 'white spirit' or paraffin family of solvents.
