Connecting Washdown pump to Lavac inlet?
hisw
20 May 2003
www.araminta.org.uk
Hi, I am after the forums collective wisdom.
I am thinking of installing a washdown pump in the anchor well (east coast mud!)
I am not keen on putting in another skin fitting so....
What do you think to the idea of installing a T just before the bowl ie after the anti siphon loop on the inlet to the loo.
Will it affect the loos function?
I look forward to your responses.
VicS
13 Jul 2002
You will be relying on the Lavac pump valves and the lid and seat seals.
You will also be drawing air in via the air bleed on the inlet pipe to the Lavac. The latter will have some effect on your pump performance
VicS
13 Jul 2002
And you may have trouble getting the pump to prime
and unless you have valve on the washdown pump you will/may draw air in through it when you try to flush the loo!
Goldie
29 Sep 2001
Nr Falmouth, Cornwall.
Can you put a diverter valve after the skin fitting? You probably won't want to use the loo at the same time as washing the deck :) I use diverter valves on my engine driven pump albeit with a separate inlet fitting; with the options to select input from the skin fitting ('raw water in') or 'bilge in'. The outlet is selected to 'bilge out' which goes out through the side or 'hose out' which goes out through the foredeck hose. The trick is to remember not to select bilge in/hose out, it makes an awful mess.....
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Why so worried about another skin fitting? Far better to have a dedicated supply for a big consumer like a deckwash pump. Use the right materials for the skin fitting and valve and you will have a proper job.
VicS
13 Jul 2002
You wait until you get older :D
rudolph_hart
23 Oct 2003
Maldon, East Coast UK
I did exactly this (and for the same reason as you) when I fitted a washdown system. I fitted a Y diverter valve, which outlets to either toilet or washdown pump -not both - and a simple, cleanable water filter between the valve and the pump. The valve, filter and pump switch are all in the toilet compartment for 'convenience'.
Been using it for 4 or 5 years now, mainly to wash weed and East Coast mud off the chain as it comes up, and the anchor before it finally self-stows. It's also great for squirting misbehaving grandkids :)
Works well.
Billjratt
9 Sep 2004
Firth of Clyde
What about a "Y" piece and a non-return valve in each of the output legs?
That would negate the need to manually change between loo and wash functions. (Installed in the loop above the waterline of course.)
I've been thinking about this for a long time as we get some mucky stuff up here as well - also teak likes a saltwater wash, so no more buckets.
rudolph_hart
23 Oct 2003
I did think of doing this, but was concerned that:
a) The ParMax 4 washdown pump's demand might 'overpower' the toilet's non-return valve, or
b) A non-return valve would restrict the flow to the washdown pump (already reduced by the in-line filter)
I fitted one in the washdown piping as a test, and it did restrict the flow, so I removed it.
Hope this helps.
Billjratt
9 Sep 2004
Firth of Clyde
Yes, I've had flow problems with non-return valves before and now fit oversized - they usually have staggered fittings anyway.
I was just wondering if anyone could fault the theory behind using N-Rs rather than a 3-way.
