stav
Hi,
Having fitted a new gearbox (last year) I have ended up with two oil coolers, one for the engine and one for the gearbox. Initially I had a bent piece of plastic tube but then soldered up a bit of 3/4" tube and a 3/4 to 1" in copper reducer. But I am wondering if the copper tube was the best thing to make the connecting tubes from?
They are isolated by the rubber tubes but I do leave the seacock open most of the time. All the seacocks are wired together to the anodes.
Will it be OK? Or suggestions for other ways the connect the two oil coolers.
Thank you.
Thank you.
