steve yates
Because of the position of the sounder and gps units, where the connections come through holes cut in the bulkhead, i decided it was tidiier to refit the old switchbox, with its 4 switches,, over them than to extend the cables down into the new bigger switchboards I have installed. This small switchbox will run a nasa sounder, the illuminated compass and a garminmap 182, plus 2 12v cigarette lighter outlets.
When it came to getting power to it, I already had a positive distribution post in the new switchbox, the 25mm battery cable comesto that and two 6mm cables take the power to each set of fused switches.
I added another 6mm cable to it to take power to the 3rd set of switches.
Q1: My positive distribution post now has one 25mm cable and 3 6mm on it, is this ok?
From the existing busbar in the big switch box, I had the battery neg connected with a 25mm cable to the busbar end stud. I then ran a 6mm cable from that stud to the stud on a smaller bus bar in the small switch box.
Q2: Is that ok? (If I had planned this, I would have run the battery to a neg distribution post and connected both busbars to that, but I didnt and dont have the room for it.)
Q3: There are two black wires at the rear of my bulkhead compass, to provide the illumination at night. How do I establish which is pos and which is neg?
Thanks.
Thanks.
