pvb
I wonder why the OP chose a Topgnss receiver? Others would seem a lot easier to use.
I'm beginning to think you're right! Any suggestions as to what would be simpler. The Topgnss receiver antenna I have does not have a manual, which leaves any purchaser completely in the dark.I wonder why the OP chose a Topgnss receiver? Others would seem a lot easier to use.
Yes, thank you. Researching plotter options now and about to sling the topics receiver I have in the bin. I have learnt my lesson in buying a very undocumented product on the cheap.Usually using some sort of terminal software and sending a command.
Did you see my post about using the NASA Repeater in the way you plan?
I don't know off the top of my head, what I meant was that it requires the GPS to be putting it out. That is, it's not the NASA gadget that requires the waypoint but the GPS unit.Which nmea sentences?
Just had a play, from output from opencpn the nasa gps repeater needs RMB & RMC nmea messages to display anything. So looks like no waypoint activated on the gps receiver then no RMB sentence - nothing gets displayed.It just repeats what it gets over nmea, so if the nmea input is providing SOG and COG it'll display it.
Just RMC providing position, SOG & COG isn't enough.
Think that's what I was trying to point out back in post 7!That could save the OP a lot of wasted time!
That would make sense. It’s assuming you’re navigating with something like a Garmin 128 at the chart table, and just want to show some of the key numbers in the cockpit. A rather old fashioned way of doing things, and not terribly useful connected only to a headless GPS receiver.
In what way? Opencpn echoes nmea coming in , if you have no filters set, and adds RMB if there is an active waypoint. The nasa repeater needs RMB to display data.Perhaps opencpn could use a tweak?
Which seems as it should be in Opencpn, what tweak does it need?
Well yes, you need an active waypoint to get RMB data, in opencpn or a receiver..... The nasa won't work otherwise, with just RMC being received even though RMC has lat,long,sog,cog. RMC on it's own doesn't get displayed on the nasa.Ah I see, I misunderstood your OpenCPN comment. I thought you meant that if you created a waypoint in that then it worked.
This is what I don't understand, because I almost never set a waypoint but I had COG and SOG out of the repeater.Well yes, you need an active waypoint to get RMB data, in opencpn or a receiver..... The nasa won't work otherwise, with just RMC being received even though RMC has lat,long,sog,cog. RMC on it's own doesn't get displayed on the nasa.
Seems a bit of a limitation...
The Garmin 152 must put them out all the time, maybe it has a default waypoint that it works from.
Might be a different firmware version of the nasa repeater then. RMB is active waypoint data. Without RMB the one I have onboard displays nothing, it needs both RMB & RMC to display..This is what I don't understand, because I almost never set a waypoint but I had COG and SOG out of the repeater.
