guernseyman
Im the press clip i saw both were banned for 5 yrs
Today the Guernsey Press comments that while the captain was banned for 5 years, the first officer is 'free to do it again'.
Any ferry which operates at full speed in fog with radar even with two ARPA and a fog signal or not.
Is operating with a reckless disregard for other vessels particularly small vessels. It may be common practice. In fact it is common practice.
Excellent common sense, I wonder if the shipowners would ever let it happen...
The Owners may agree but the Charterers will most probably not and then the disputes begin.
Many ships with large engines cannot operate for any length of time at low speed as their engines are not designed for that purpose.
Setting the speed limits by reference to engine settings, say; Half Ahead to be the limit. This would result that 15 knots would be half speed for the Condor but well in excess of the Full Ahead for other vessels.
Slow running means that some ships have to change to Marine Gas Oil (MGO) to function rather than Intermediate Fuel Oil (IFO) which is very thick. This doubles (approx.) the cost of fuel whilst using MG instead of IFO. The low sulphur oil is also required. Who will pay?
You could argue for 8 knots maximum but that then leads to longer encounters and the ferry chap is correct in his assertion that speed for a vessel capable of operating much more quickly than those around them can make a huge difference.
In short, proper bridge management (seamanship we used to call it), a good look out by all available means and an ability to stop in the visible distance (better half the distance) is what is required. And 'Yes' (IMHO) the sentences make a mockery of the results of the incident but are appropriate to the crime itself.
You reduce speed to such a level that you can stop in time to avoid a collision. That's where the expression "feeling your way through the fog" comes from.
BTW - Mariner69 , surely the sentence must be influenced by the out come of the crime? I see the luck rather than judgement aspect, but if you cause death or injury on the road through negligence you can expect a harsher punishment than if you had merely damaged property.
That expression is from pre-radar days. Are you suggesting that vessels come to a full stop in zero vis? How practical is that?
For goodness' sake, I can see every little boat (except perhaps an inflatable under oars) on my inexpensive entry-level Furuno..!
The bottom line is that it was speed PLUS inattention that killed.
I hope the bereaved families have adequate access to the law to enable them to succeed in their civil action against the company.
To be fair with the dual radar set up on the Condor boats you can see pot markers, small boats, birds even. There was no trouble 'seeing' the Marquesis it's simply that everybody was too engaged having a chat to do anything about it. That's what angers me - it's just pure negligence. 38knots may be excessive in fog, it may not, maybe 20 would have been more appropriate, bottom line - they had expensive top end kit, which they failed to use , they could have killed somebody travelling at 6 knots in those circumstances. I personally feel that 38knots is too fast if you are relying solely on radar, a slower speed (even by 10knots) would increase the time you have to search for and identify targets by 25%, but I'm a recreational sailor, not an commercial HSC skipper, in any case as I said, they weren't looking anyway. BTW - Mariner69 , surely the sentence must be influenced by the out come of the crime? I see the luck rather than judgement aspect, but if you cause death or injury on the road through negligence you can expect a harsher punishment than if you had merely damaged property.
At least reduce speed such that the impact is a clang rather than a death. Many vessels used to anchor in fog rather than risk it.
The Condor is a cat so may well have gone right over the Marquises as opposed to a mono hull pushing her asideIf you advocate vessels anchoring when it gets foggy, the cost of products in the UK will see a dramatic rise, due to the increased cost of shipping. I can't remember the size difference, but Condor vs Marquises is something akin to lorry vs tin-can; any speed would have been devastating to the smaller vessel.
