emnick
Hi All,
I want to have my injectors checked and cleaned, while they are out I would want to do a compression test. I have a decent (Snap-on) compression tester which is caliberated up to 250psi, I need to know (1) if this is to low for a Diesel Yanmar 3jH series engine (2) can I buy an adaptor to fit the injector thread as I have a conventional spark plug hose connection on gauge (3) Recommendation for injector cleaning people.
I want to do the test as when I was bleeding the injectors today there was a noticable less drop in revs when pipes cracked open on two of the three cylinders (middle cylinder caused more of a rev drop than 1&3).
Engine had run for about 5 mins prior to opening each pipe. There is also a slight 'diesel knock' from the one that caused most rev drop (hence clean the injectors).
Thanks in advance for ANY help.
