zoidberg
I'm looking for professional expertise in composites. Someone to tell me how many layers of what bi/tri/quadraxial glasscloth to bond in, for a specific reinforcement task.
Any pointers?
Any pointers?
Any pointers?
I assumed that.... but apparently not. I've asked several, as you might imagine, and they've all backpedalled, citing concerns about 'liability insurance'.Surely reputable retailers of fiber glass resins and glass products would have experts on their staff who could advise?
Very many years ago - when it was something state of the art, not a routine add-on to engineering drawing software - I worked with FE modelling of glaciers. I didn't develop the FE bit - that was code we got from elsewhere; I just made it work in our environment, and wrote modules to automatically generate meshes so we could run it for a time step, then generate a new lattice at the next time-step and so on. But it uncovered one of the limitations of FE modelling - it's very difficult for it to handle changes in the regime. We were hoping to model glacier surges (which result when the glacier becomes decoupled from the rock beneath) but were unable to use FE modelling to model the decoupling mechanism.I have a mate who designs things in metal, plastics and composites.
I think the problem will probably be that you can only guess at the loads on the reinforcement.
And then you won't know how much it's acceptable for the thing to distort under load.
For most bits of boats, there are scantling rules and designers' 'rules of thumb' which have proven adequate over the years.
If it's something like a simple beam, you can find basic calculators online to work with the sectional moments of inertia and the materials properties.
The properties of glass are fairly well known, just work with the fibres which are aligned in a useful direction.
It's simple enough for easy problems like 'how much glass do I need for my centreboard not to break when fatboy rights the dinghy by standing on the end'.
For more advanced questions, you may need a 'finite element' model of the whole structure with all the loads and accelerations modelled.
People in this line of work tend to run away from vague questions or offer to do a lot of work and charge you a lot of money.
F1 teams and aeroplane designers are prepared to pay.
If you're willing to dig for the answer:- Google Scholar
Some problems are just not amenable to computer models.Very many years ago - when it was something state of the art, not a routine add-on to engineering drawing software - I worked with FE modelling of glaciers. I didn't develop the FE bit - that was code we got from elsewhere; I just made it work in our environment, and wrote modules to automatically generate meshes so we could run it for a time step, then generate a new lattice at the next time-step and so on. But it uncovered one of the limitations of FE modelling - it's very difficult for it to handle changes in the regime. We were hoping to model glacier surges (which result when the glacier becomes decoupled from the rock beneath) but were unable to use FE modelling to model the decoupling mechanism.
At what temperature? Mind, granite melts are pretty viscous, unlike basaltic ones.Some problems are just not amenable to computer models.
Tiny changes in the boundary conditions create big changes in the outcome.
Reminds me of my uni tutor who had a habit of writing complex equations involving factors like 'the viscosity of granite'.
The compressive strength of GRP is about 120N per sq mmI've done a bit of that, relating to the bolt/composite design task. It's rather complex, especially as the expert composite engineering academics have yet to agree what is meant by 'strength'.
( ShieldSquare Captcha ; Simplified procedures for designing composite bolted joints - NASA Technical Reports Server (NTRS) ; https://apps.dtic.mil/dtic/tr/fulltext/u2/b108123.pdf ; https://www.matec-conferences.org/articles/matecconf/pdf/2017/17/matecconf_iscee2017_02031.pdf ; and more )
I looked at this arrangement which 'looks strong enough', then thought there may be a better way - with answers to the questions 'why...?'
I can think of no good reason why the reinforcement cannot be on the inside. I'm looking to secure a pair of padeyes to the quarters, like this, but not using sticky tape.
These titanium padeyes are rated at 'in excess of 20,000lb' in shear. The 12mm BUMAX 88 bolts each can manage that. The Max Laden Weight of the boat will not exceed 9000lb. That's my target spec. Don Jordan's calculation of 'Design Load' onto each padeye is not more than 5040lb.
How many layers/laminations of what spec of cloth/tape, with some numbers? Shouldn't be this difficult....
I did make the stoodent error of asking similar, or 'how do you measure that' and got trapped into a 45 minute monologue.At what temperature? Mind, granite melts are pretty viscous, unlike basaltic ones.
I assume it's for one of those drogue thingies which holds the boat back enabling overtaking waves to smash the rudder.It is difficult to be sure - but I suspect that the titanium padeye needs to be rotated by 90 degrees to actually have the strength you quote. AS mounted it would suffer both shear and bending stresses - which padeyes ae not generally rated for.
It will if overengineering it transmits the overload from where it arrives to an unreinforced part of the hull; consideration of where you'd like the failure to be is as important as making things strong enough."You can get a lot of glass and resin for the price of the time it takes to explain your problem to a consultant."
My thoughts exactly. Don't overthink it,
The engineer can build anything to a minimal spec., If it's over spec, will it matter?
