Compass adjuster
stelican
25 Nov 2004
fareham hampshire
I have been advised I should have my boats compass swung,Can anyone put me in touch with such a person. The boat is on a trailer is it possible to swing compass whilst ashore and how much can I expect job to cost. The boat is in Fareham Hants
gonfishing
21 Jan 2003
Seems a bit radical to me, unless of course you intend going blue water cruising or do Atlantic crossings!!! If you have any mates out on the water next time your out, get together say 2 or 3 of you and point boats in same direction and compare compass readings obviously there will be come discrepancy but for your average inshore cruising not a problem however if yours is reading way out compared to the others change the compass for a new one. Far cheaper than trying to get the compass swung!!!
IMHO
Julian
D
Deleted User YDKXO
Whats the point in that then? The whole reason to get a compass swung is to take account of deviations caused by the boat itself so changing the compass will just give the same wrong bearings again /forums/images/graemlins/smile.gif
D
Deleted User YDKXO
Get a local chart, find 3 or 4 transits (2 solid objects in a line like lighthouses, headlands, shore marks, piles - not floating buoys - they can move) and measure the bearings of the transits. Take your boat out on the water, line it up as accurately as you can with the various transits, record the compass readings and compare with the measured transit bearings you've got from the chart not forgetting to add/deduct local magnetic variation. If the compass readings are more than 1-2degs different in any direction, get the compass professionally swung
mjf
18 Jun 2003
w.london - boat on solent- RIB on Tidal Thames
I agree with Deleted User, you can take bearings of transits around the 360 degrees and make a deviation chart yourself.
If the bearing are out by more than say 5/10 degrees then you ought to recosider your options again.
How do you use the compass, for steering or for navigation or for both?
As a thought - I have a compass on my 'boat' watch and it is amazingly accurate
hlb
RIP
Any Pub Lancashire or Wales
A compass on a trailable boat is about as much good as a chocolate teapot anyway. Not many folk use them much these days anyway. Just get a GPS and maybe a chart plotter. Then take a note of the compass reading on each heading. Mines about right on some headings but miles out going east. Keep the notes and if ever the GPS goes down, at least you have something. I've been promising to do it for about the last ten years! /forums/images/graemlins/shocked.gif
miket
21 Jun 2001
N Hampshire
I always have my compass swung whenever I change boats.
As a club we get half a dozen boats together and a super chap called Roger Muir from Eastliegh area comes up and charges about £50 a boat.
To my mind it's not worth buggering arounf doing it yourself for that kind of money.
David_J
29 Sep 2003
South East
My compass is way out on some headings. Like way out, both of them so its not just what they are mounted near. I have put up with it so far and used the GPS but if I was to rely on the compass, well a bit scary. One day I will make a deviation chart comparing from the GPS. Cant afford swingy thing for two compass's
hlb
RIP
Even the royal navys compasses are out. Your supossed to have a card with about twelve different headings and deviation. Once that is done it dont matter if compass is out. Get a GPS anyway.
Wiggo
10 Sep 2003
In front of the bloody computer again
Easy enough to do - we swung our upstairs one in November against the fluxgate/gyro thingy. It was at worst 10* out, but at least we know now. I have to say, overall, if the leccies did fritz completely, I'd be happy enough to find the coast and then coast hop home. So a 10 degree error from mid channel would still land me on a recognisable stretch of coast. Doing it in the dark might be another matter, I suppose, but yer man here has a trail boat, so unless he's as daft as Brendan, he won't be out in the dark...
stelican
25 Nov 2004
fareham hampshire
Thankyou for your opinion. I am planning to do several channel crossings this season and I am cautious of fog and dont want to rely on electronics.I am surprised at the Hap-hazard way you suggest to check the compass.I take safety at sea seriously ,Do you realise how off course you can be after a 60nm passage with a 10 degree compass error.
I have just got a quote to swing compass £130+vat boat will have to be launched job will take about 20 minutes. seems a bit expensive but chap tells me he usually does supertankers and mentioned 5 year apprenticeship to qualify.
Wiggo
10 Sep 2003
ah well. Fog's another matter, IMO. It's very easy to get completely disoriented in fog, and given the way a mag compass swings about underway, they can be useless. We got caught in awful fog in Lyme bay, and the combination of my corrections and the steering compass was so useless that I almost had to stop at times. GPS is no better, as it computes a heading based on last position, so it only updates every few seconds, and radar only updates every rotation.
Between the lot of them, at times there could be 100* disagreement! So I bought a fluxgate/rate gyro.
Anyway, fog in the channel rarely extends from one side to the other, so I doubt you'd be going 60 miles at 10* out.
A bit more detail on the boat in your bio might give people a better idea of the sort of answers you're looking for.
mjf
18 Jun 2003
Bollox!
Its part of the exams for Masters' FG or Class 1 Cof C these days....
Yes, you should take these matters seriously as all the above people have done.
The point is that in a smallish boat you will not be able to steer to 10 degrees accuracy - period. So as long as you know your deviation for an arc of the compass , apply it and steer the resultant to obtain an average CMG of roughly what you need. I assume too that you will have computed the tide affects for the passages - this will throw you much more that a bad compass - more than the 10 degree issue unless of course the thing is a basket case but you will know that from comparisons with GPS/other compasses and indeed other boats.
BrendanS
11 Jun 2002
Tesla in Space
You didn't see Jan PBO article on Pathfinder Powerboat Club then?
loads of trailer boats out in the dark /forums/images/graemlins/grin.gif
stelican
25 Nov 2004
fareham hampshire
Thankyou Wiggo but my reply was not addressed to you but to Gonefishin ,I take it he uses a net but thats another matter.
However I have a very large compass that is extremely well damped and as my boat is quite small I only go out in calm weather s oit is relatively easy to hold a heading
stelican
25 Nov 2004
fareham hampshire
Hello mjf
I dont know what you do or did for a profession but your first para reads like gobbledegook.
I obviously take tides into consideration when heading in any direction apart from east or west.
I do make use of my plotter gps and autopilot but I am cautious these could fail.
hlb
RIP
Think you need to hang about a bit before you rubbish every ones oppinion on here. There must be a few hundred thousand sea miles between us!! Against good electronics a compass is next to useless, ok if all else fails, but mine never has.
