demonboy
I used a single layer that seems perfectly adequate.
:encouragement:
For the last sealing job, on a leaky stantion base, I used Screwfix Silicon.
£2.95 a tube.
They do, because the one advantage of silicones over most other sealants is that they contain no solvents that might react with the plastic log fitting that NASA supply. I assume that they have had some adverse feedback about solvent based sealants but other makers who supply plastic fittings seem to have no problem with better sealants.
That's a pity because I find silicone sealant a bit messy to use. I've used PU40 under some other plastic skin fittings so am tempted to ignore NASA recommendation. Also I'll probable ignore the instruction to glass it in internally.
. Can also happen over time if you are a bit too enthusiastic in tightening the backing nut!
Is Butyl Tape ok for use on seacock skin fittings?
That looks just the same as the stuff I used to bed one of my wheelhouse windows on Cecilia. It is what Mainbrace in Milford Haven use for all similar sealing jobs. It has worked fine in excluding water but seems to continue extruding almost indefinitely. I used a single layer that seems perfectly adequate.
' That recommendation is there to prevent the whole fitting becoming detached in the event of the outer flange being struck and cracking off from the threaded tube. '
How likely is that!
I'm about to fit a semi flexible solar panel (aluminium backed) onto my boat's sunroof (GRP).
I want to use a sealant / adhesive, which will keep the panel in place and stuck down in all weathers.
I also want it to be removable in about 10 years time without causing damage to the sunroof or being a total pig of a job when the panel eventually expires.
What do the forum experts recommend?
I'm completely confused by the information above - a case of too much and too little information I think.
Use CT1.
