boatmike
I am trying to compare fuel consumption over a given distance for semi displacement boats like Aquastar 33 and the equivalent full planing offshore cruiser of the same waterline length. Assume say that both boats have twin Volvos of 200 HP each then the fuel consumption PER HOUR should be the same for the same RPM i guess. The semi displacement boat however will be working very hard to do say 15/16 knots while the planing boat should use considerably less fuel once up on the plane and for the same useage of power will go much faster. This means I guess less fuel usage over the same distance. But how much less? And is it most economical to go no faster than the lowest speed the planing boat gets up on the plane or is it more economical to go faster using the engines full power? All this will depend on sea state of course so the question has to be if conditions allow. Anyone got any figures?
