Companion way spray hood
Sounds like you are after something like this
Yup probably a bit more elaborate than I had in mind but its the sort of thing that I was thinking about.
Is it yours?
Ian
I also noticed your mount for the plotter (Standard Horizon?) The only thing that is keeping me from doing something similar is leaving the leads exposed to the elements. Do they live permanently outside or do you pull them inside when finished with them?
I had a somewhat similar arrangement on Kindred Spirit. The cable stayed connected to the plotter, but the other end was cut to length and fitted with a Buccaneer waterproof plug to match a socket on the coaming. The socket had a blanking plug that could be screwed in place when the plotter wasn't connected.
