fergycool
This is my first post on any boat forum so be gentle…..!
I’ve recently acquired my first boat (with an engine, or two) and I’m acquainting myself with its workings!
The boat has twin engines with a starter battery each along with a single domestic battery.
The wiring is a bit of a hotchpotch with any old colour used so I’m having a difficult time making a wiring diagram (which of course does not exist!).
The -VE side of all three batteries appear to be connected. These are not wired in parallel as the +VE side is completely separate. However, if I take a reading with a voltmeter across the +VE post of each battery to the -VE busbar in the distribution panel I see 12/14 volts with the correct polarity.
I understand electrically that this is fine. However, in terms of best practice of boats is this correct?
I understand that the earth of the 240v AC circuit should be connected to the -VE of the DC circuit. Is it correct practice to bond the -VE of the starter batteries as well, or with a common negative is it assumed that this is the case? I guess that if the -VE of all three batteries are bonded to AC earth then they will be connected to a common -VE. However, whereas I understand the safety aspect of bonding the -VE of the domestic 12v system to the earth of the 240V AC system (to provide a route to earth if any 240v current crosses to the 12v circuit) I do not understand the need to bond the -VE of the starter batteries as no 240V AC circuit would be anywhere near there!
Incidentally it’s a simple AC circuit with 3 x 13 amp sockets from a RCD protected 16A breaker. The earth is broken between the shoreside input and the earth bonding point in the breaker with a galvanic isolator. The steel hull is also bonded from the boat side of the galvanic isolator.
I am working my way through the Nigel Calder book (cracking read) but this point is one that I’m still unsure about. Google has proven elusive on a definitive answer and so I ask here?
Any advice would be gratefully received!
Cheers
Chris
Cheers
Chris
