mattonthesea
I am really interested in why you think this product will meet those requirements? Why is it ecofriendly when most of your energy requirements will be produced by running the diesel engine, either as a generator or by exploiting the unused power output when motoring? You are hoping to reduce solar - why when it is the most eco friendly? Your boat won't go fast enough to get any meaningful regeneration. It does not need lithium, but you will have to increase your storage capacity enormously (and of course lithium helps in this respect) to get any significant range under electric only - and then have to run the diesel to replace it unless you have access to shorepower.
Hybrids start to make sense when the domestic power requirements exceed the propulsion power requirements, which is not the case on a yacht like yours where your domestic requirements can be met with a combination of solar and the by-products of diesel propulsion (hot water and alternator output). If you look around you will find successful hybrids in yachts are serial - that is diesel electric but these are large craft with high domestic requirements (cooking, A/C, fridges, freezers, washing machines, watermakers, power sailing systems and so on) that also sail fast enough to get meaningful regeneration through their electric pod drives. Plenty of examples on the Oceanvolt site of such boats.
As I said, I am happy to be proved wrong, but I have yet to see anything convincing.
- quiet
- better eco friendly
- trying out a potential positive change
- fits with lithium setup
- possible less solar required
- more to fettle
We generally start the engine only a short distance from out finishing point. So the range is unimportant on those instances. A quiet engine means I'll be able to hear my partner on the bow. Standard charging with a 80w gen is extremely inefficient. With a lithium set up and that powerful gen any charging will be very quick if we need it. I can add more batteries if needed. So less engine time required. Less wear and potentially less pollution.
When in marinas we can charge up quickly from shore power. That little bit of engine use to get on and out will provide some charging and that may be enough to mean that we don't need as many solar panels.
I see this as a challenge for improvement. It may not be a massive plus but it may make life a bit more interesting and fun. That's why I said it's a potential positive change.
And I enjoy this sort of thing
The real question for me is whether I can afford to have fun!
Hope that answers your questions. And I quite agree that all the research days I'm bonkers
