Samosun
Hi, I've just bought a 1980 Colvic Sailer 29 and am very happy with her Currently out of the water for a couple of weeks to do some bits and bobs.
Even though they are pretty common there seems to be next to no information about these boats construction other than solid, stable, safe.....which is how every bilge keel from the 70's and 80's seems to be described. I was hoping there might be some people who have owned or worked on them and could answer some questions....
Keels
I know these are encapsulated and from what I can find iron/steel was used as ballast. Does anyone know what form this was in? Was it small pieces 'potted' with resin? are they solid cast lumps? There is a small slightly messy repair on the front bottom of one keels which a well know surveyor mentioned in the survey but that was it. Clearly it didn't concern him. but it doesn't look to me like it's completely watertight so wondered if it's worth grinding back and doing a better job with epoxy or just leaving it for another year.
Rudder
Does anyone know the construction of these? I assume it is a solid steel shaft with 'paddles welded on, and then a fiberglass shell with some sort of filler (foam probably?) It's a bit tatty and again mentioned in survey but just saying 'keep an eye on it'. I can't say it worries me but I'm curious if anyone knows for certain how they are constructed.
Deck
Does anyone know if the deck is cored and if so where and what with? The deck is very solid everywhere except for a section between the bow hardware and the coach roof. There is no cracking, just slight flex with my 90kg bouncing on it. there is also no hardware or holes in this area for direct ingress. It feels more like there is solid core or thicker layup under the windlass, cleats etc and just thinner layup where there are no fittings in the deck.....or maybe it's is rotten ply core? Again I can't say I'm that bothered, but curious if anyone has drilled into these decks and knows the construction in different areas.
I'm planning on keeping her for a long time so really trying to understand the construction and find out what needs doing now and what can be done at a later date when I haven't just blown all my money on a boat Thanks in advance for any answers.
Keels
Rudder
Deck
