Poignard
Mandate compulasry use of AIS transponders on all vessels.
Job done.
More laws = more busybodies meddling in our lives. No thanks! There is no necessity for it.
Job done.
And overload the system to such an extent that it becomes worthless. Brilliant.Mandate compulasry use of AIS transponders on all vessels.
Job done.
There are those who fail to recognise when there is a problem. There are those who recognise when there is a problem, but cannot be bothered to consider it. And there are those who recognise when a problem exists, and are given to considering how best to address it.
Consider, for example, the problem and practices of civil aviation - light and heavy commercial..... Similar admonitions to keeping a good lookout at all times. However, aviators are aided by the use of attention-getting strobe lights on wingtips. In the vicinity of an airfield and on the approach, most aircraft will also switch on a powerful landing (search)light, the better to be seen. Look up at night and in reduced visibility and notice how much more readily your attention is caught by such 'technical aids'....
In a crowded Solent ( or similar ) at night, notice how the small vessels with strobing orange or blue lights - as well as ordinary 'steaming lights' - immediately stand out from the huge array of shore and other lights and catch your eye immediately.
I've never understood the IMO proscription on the use of strobe lights. Lots of recreational boats around the US use masthead strobes for occasional use when deemed necessary. I myself carry a handheld MilSpec strobe as an 'attention getter' which I've used to very good effect twice in decades.
Are rules for the 'guidance of wise men and the obedience of fules'.....?
Having sailed single handed from Brixham to Chichester, entailing 20 hours single handed on the helm, I was able to keep a good watch.
I have, in the past. competed in 24 hour competition hikes and have found that between 0100 and 0300 I have to concentrate on keeping awake. During that period I tend to operate in 'autopilot mode' after 0300 I seem to wake up.
I've found the same when sailing.
So I ensure that I find plenty of routine things to do. Just sailing there is ample opportunity, when solo, to nip below to put the kettle on or go for a pee without jeopardising your watch-keeping abilities. Have a good look around, nip below, keep glancing through any ports below, do what needs doing and come back up.
A lot of it is establishing a routine.
At night I tend to keep the radar on, with a guard set.
When was the last time you were in danger of colliding with 2000 vessels within the next minute? If it's frequency saturation you're worried about that's not a problem with class B due to power output.
Start of the RTIR perhaps. Certainly the oil tanker a mile away bearing down on you is not going to be noticeable amongst all the other AIS systems transmitting, which'll make AIS useless as an aid the keeping a lookout.
But why bother?When was the last time you were in danger of colliding with 2000 vessels within the next minute? If it's frequency saturation you're worried about that's not a problem with class B due to power output.
Singlehanding around the Atlantic I've ended up running the boat like this...So, what could or should the 21st Century yachtsman do to enhance his ( her? ) chances of meeting the primary objective of the ColRegs - avoidance of a collision at sea - with especial regard to Rule 5, harnessing today's technology? How can we, in our own best interests, do better in terms of 'see and be seen' or otherwise be adequately observed?
I confess that this year , whilst single handing in the Black Deep I was missed by a large container ship by about 40-60 feet
The ship did not see me & I cannot understand how I could not see an object of thousands of tonnes.
They must have had a look out in such a narrow channel but made no sound. In fact I did not hear a thing untill the bow suddenly appeared over my left shoulder
Thing is, if I had had my wife or another crew aboard it does not mean they would not have been down below reading a book
If I am single handing, radar or AIS would be useless as there is no way ( being a serious seas sick sufferer) I could go below to look at it
Some times in rough weather, when I am with a crew or not, they or I cannot get below to read instruments or turn off that damned DSC alarm
So the real issue is not so much single handing ,but the duty of those assigned the task to keep a proper lookout.
That near miss is not the first time. 40 years ago I was so close to collision with a large unloaded ship ( The prop was partly out of the water) that the water spray from the prop went into the cockpit. We had 3 on board & once again it was carelessness that almost cost us our lives.
But why bother?
What is the problem you're trying to solve?
No range control on your display?
They are not all threats. You just need to set TCPA thresholds to appropriate levels.
