Ardenfour
My eggshell-blue grp on the deck and cabin top has various chips and gouges that I'd like to fill. So how do I match the colour, and what could I add to white gelcoat to arrive at a close match?
... and I believe there is at least one other good supplier on the East coast somewhere. Someone will be along with that soon...
I do this for a living but its easier to watch this vid than for me to explain.
http://boatworkstoday.com/archives/1512
Obviously if you get it right you can't see the repair and this is always the aim.
The hardest is on molded non-slip which is a bitch to get right.
I find with white boats that I add yellow normally and on odd occasions some grey.
For eggshell blue I'd start with white and add a tiny touch of blue until matched.
Now for the tricky bit.
If you use topcoat/flowcoat gel it will go off un-sticky however if the repair is more than a couple of mill deep you run a high risk of air bubbles that will appear when you sand back.
You shouldn't recoat over top or flowcoat as its pre mixed with wax that comes to the surface during curing.
This wax needs to be sanded off before the next coat.
So I usually use normal gelcoat and put on 2 or 3 light coats but un waxed gell will not cure totally and remains sticky so I have to mix the last coat with a little Wax in Styrene so it sets of hard.
You can cheat sometimes on the last coat by waiting 10 minutes after you apply the last coat and then carefully putting a piece of tape over it to cut off the oxygen if you don't have any wax though frankly its cheap as chips.
Finishing I scribble over the cured gel with black marker pen and sand off with 320 grit - then repeat this process with 800, 1000, 1500 and 3000 grit wet and dry.
Then finish off with 3m cutting compound and buff.
