petersto
About to buy new batteries for my Centaur, engine MD11C 23HP, 17Kw manual say 70AH(max) but no mention of cold cranking figure. Any ideas?
We have an MD17C and a 100amp cranking battery for 35 HP. Obviously you can go lower.
I'm thinking of using a motorcycle battery. For example this is small and has sufficient CCA
Thats exactly the kind of thing I am looking for Phillm and my sort of price. I want two of them not interested in leisure batteries havent got a lot to run, keep it simple use No1 one day No 2 the next day through change over switch. Have lead acid now lasted 9yrs and they came with the boat, so who knows how old. Thanks very much for all comments I would still like to know the cold cranking though.
I've measured cranking currents on small diesels and it's about 200-250A. I suggest a battery at least twice that. I suggest it's better to have a dedicated start battery with a high CCA and low cranking marine/leisure type batteries for the domestic bank. Reason is the high CCA batteries don't like deep discharge and deep discharge batteries don't like high cranking currents, horses for courses.
I also liked the price. Although having to fork out another £15 for a battery box to fit it and it taking half a day to switch them over, sort of took the shine of the experence.
been toying with the same idea of adding an engine only battery. my engine is a 3 cyl 29 hp volvo so presumably the same CCA as a yanmar. but is CCA and the voltage the only criteria to specify? ie no need to worry about amp hours capacity.
i have3 domestic & 1 engine batteries all the same 115 Ah sealed so called heavy duty .
works for me
Depends on what "heavy duty" means. There is a range of battery types spanning leisure batteries and starting batteries, they will all do a job but batteries are designed to do certain jobs well, compromise is compromise.
in sailing, one has to compromise, doesn't one![]()
