Tim Good
My gunwales are flaking on a boat I bought last year. On the sides they are ok but on the tops, exposed to more uv or frost, they are bad. I found some documentation that the previous owner used Coelan.
I'm a little nervous to use is given the price and mixed results people have had but since I'm no removing every bit and starting again then it might be a good idea to continue using it. My questions:
Is it worth it or will another varnish be perfectly fine as an alternative?
Can I just rub down the existing areas which are ok and add a another coat like with normal 2 pack varnish?
