Cockpit lighting - sailing yacht
I've never seen it as a problem. It doesn't get dark in the Baltic until about 11. However, you could buy a Malo. One I went on years ago had a line of lights built into the windscreen/sprayhood.
We got a great light from Lidl. It has 3 brightness levels and a soft white rubbery light dispersal 'bubble'. It is charged by usb and also has a fly killing zapper mode. It hangs from a little retractible hook. Typing 'enkeeo 2 in 1' into google seems to get something similar
Do you have wheel or tiller steering?
I bought some small individual leds off eBay and fitted three to the underside of the instrument pod plus an on off switch. 2 of the less twards the back lighting the end of the cockpit and a third lights the table attached to the front of the pedistal. I’m pleased with the result. Use a warm white led as the normal led is too bright/blue. I wanted a permanent solution and I’m pleased with the result.
I've got a couple of Aldi led battery lanterns which I can hang from the boom, can also double as emergency compass as they have compass in the top!
Clearly I am doing something wrong as my ratio is 99 hours sailing to 1 hour lounging about in the cockpit. Do you guys ever sleep?
I know what you mean OP. And I was even considering some vulgar Sunseeker style lights in my cockpit sides at floor level.
However problem solved with one of these...
https://www.amazon.co.uk/Bottle-Lig...-spons&keywords=lights+to+go+in+bottles&psc=1
Put inside your favourite empty bottle and it looks absolutely excellent IMHO, and can simply be lifted up and put on the saloon table when it gets a bit chilly.
I bought an LED "hurricane lamp" on ebay for £8.99. Does the job and looks the part.
I've been looking at these for our summer tenting fortnight next month. I'd prefer a real oil lamp, but if an LED equivalent gives a controllable yellow glow rather than a cycle-headlight white glare, and if it's built to last and not too battery-hungry, I'd like one...
...but there are so many, and so cheap, it's hard to know good from bad. Any specific recommendations from contented buyers?
I fitted boom lighting. They are concealed in the track on the underside of the boom. The difficulty is getting power to them so not a quick install. Bought from Calibra Marine
You can get water proof strings of LED xmas lights powered by a few AA cells in a waterproof/splashproof box for a few quid.
Run for many hours.
Not bright enough to read a book by, but enough to find your wine glass.
Run for many hours.
We have something similar but for garden lights so solar powered. The string of them across the back of the Bimini also tells us which boat is ours in a busy anchorage. On the table we have big wax candles with led candle flames which work nicely with a meal and used to be amusing in a breeze but now everyone knows what they must be.
