WilfA
New Member
What type of hose would you recommend for connecting two cockpit drains to seacocks (seacocks below waterline).
Each hose length is about 500mm, internal diameter 1 1/2 inch . Hoses do cross. Current hose is green PVC, lightly corrugated outside with PVC spiral, semi transparent hose . It took the curve of the crossing fine when installed 12 months ago (when replacing the seacocks) but one hose has developed a kink just above the end of the seacock hose fitting. The curve shape must have caused the corrugation to collapse over this period. Wondered if anyone had a good recommendation.
