Chuncky
The spigots on my cockpit drains are 42mm o/d. I therefore need a 42mm I/D hose to connect the spigot to the skin fitting. I've read a few threads about heating a 38mm pipe to fit. To install the pipe you need to climb into the sugar scoop via a small aperture and then lie across the scoop in a very small space. The prospect of wrestling with either boiling water or a heat gun to make a 38mm pipe fit the 42mm spigot in this space is not attractive, to say the least.
On a positive note I've noticed that 42mm is a standard size for engine cooling hoses, so I'm thinking that I'll go down the route of getting a very snazzy coloured 42mm silicon hose. As the duty is to carry ambient temperature rain/sea water at ambient pressure, I can't see a downside to this duty, apart from the cost of the hose.
What am I missing?
What am I missing?
