Sea-Fever
Hello all,
When i was searching for a new boat, one of the plus points of the Westerly 33 that I ended up buying was the fact that the headlining had been replaced. In fact it is one of the neatest and good looking jobs I've seen.
Now I am the owner I am looking to fit a canister liferaft on deck somewhere to maximise access and save space inside. The coach roof is an obvious spot but I don't fancy drilling through the GRP for the following reasons;
1. I understand it is wood cored and this would leave it susceptible to rot.
2. Any hole risk leaks into the saloon
3. It would ruin the look of my lovely headlining
So, does anyone have an alternative method of securely fitting a liferaft to the coach roof without drilling through? I was thinking maybe a teak pad(s) epoxied to an abraded coach roof onto which a standard liferaft frame could be bolted....however I'm not sure how we'll this would hold. Having the liferaft washed off the deck just when i need it sounds depressing....so any fixing has to be pretty good.
