Cloth/resin right behind prop. How many layers?
vic008
18 Aug 2007
CHCH. NZ
Went back to ply right behind the prop. Wondering do I need more layers of cloth/resin for there. Just done 1 layer of cloth
William_H
28 Jul 2003
West Australia
One layer of cloth IMHO on wood is not good. It will delaminate fairly quickly. You need either just wood with paint or go for really thick GRP that will in effect stand up alone as GRP with a wood mold. (as in 6mm thick at least) ol'will
Stemar
12 Sep 2001
I don't understand that. If I'm not mistaken, there are many wooden boats that have just one layer of cloth over the wood then paint - Look at Victory, the tender Art of Boatbuilding built for Arabella, for example.
A good coat of thin epoxy on the bare wood to soak into the wood followed by the glass cloth put on while the first coat is still tacky then faired and painted should last for years. Of course, the wood must be good and dry, or nothing will stick, not even paint.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
I owned a small motorsailer that had a plywood pilothouse roof that had been sheathed with GRP, rather poorly. When I began to repair it the adhesion between polyester and ply was so poor that whole lot was easily pulled off, a couple of metres square. I redid it in epoxy, which was immovable once cured.
saxonpirate
7 Jul 2007
Falmouth et la belle France
I'd go with that.. but I note you said 'epoxy' and not polyester.. As you obviously know.. polyester is a lousy glue.. The other big factor that you mentioned of course is the moisture content of the wood to ensure a good bond, and that I believe is around 8/12%. Don't quote me on that mind, I haven't confirmed that, its just a figure I remember from my days working with SP Systems Resins..
Tranona
10 Nov 2007
Will have no effect. I had a deadwood and rudder sheathed in epoxy glass, single layer in close proximity to the propeller for over 20 years on a previous boat with no adverse effect. don't forget you will be adding antifouling paint on top.
