Clipper Depth problems
timb
28 Oct 2004
Argyll Scotland
I have a clipper dual speed and depth instrument on board and the depth reading appears to be all over the place and when in deeper water it reads scary depths of 2 - 3 meters. It also keeps flickering between "OUT" and a depth reading.
The transducer is bonded inside the hull in front of the keel.
Can anybody give me a clue as to what to check.
Strathglass
Fife
Perhaps,
You happen to have bonded it to a part of the skin which is too thick or just too near the keel.
Can you remove it from the present position and see if there is a better place?
What is it bonded with? That may cause a problem.
Iain
simonfraser
13 Mar 2004
hull too thick possible, more likely air in the way somewhere, either inside whatever you used to stick it on or turbulence in the water under (hopefully) your boat
dmayes
22 Mar 2005
Berkshire
www.drmsom.com
If you "bonded" it, did you use epoxy resin? if so you may have trapped bubbles under the sensor. You may have to try to get it "unbonded" then test it in water. You should be able to install it in an oil bath to prevent air getting beneath the face.
broadcaster
6 Feb 2004
Our one sits in a tube bonded to the hull which is filled with oil.
Not sure if is the NASA transducer or a Stowe one interfaced. When our's did this I needed to top up the oil.
Andy
timb
28 Oct 2004
Argyll Scotland
I did not actually fit the transducer it was already there when I bought the boat.
I should have mentioned earlier that it seemed to work fine last season before standing on the hard for 4 months.
I will have another look to see if I can determine what it is bonded with.
JAYEL
23 Oct 2004
Essex England
I had a NASA unit with exactly the same symptoms, but only with the engine running. Turned out to be interference fron alternator. Re-routed cable, problem solved. Just a thought! Good Luck.
SteveGorst
10 Dec 2002
CONWY
Just a thought which is probably totally off the wall but I know these transducers are thrown out by any air voids. If your boat has been on the hard for 4 months and the hull has dried out could it be that there are some voids somewhere in the hull that had previously contained water?? As your boat remains in the water for a bit longer maybe the voids will refill with water and your transducer will start working again.
As I said this is just me thinking aloud, or brainstorming as we call it at work, so don't place to much emphasis on it. But if it does start working again after a few weeks....
Dipper
30 May 2001
Dorset
I had a similar problem with my NASA depth sounder in shallow waters after working perfectly OK for years. It also kept jumping around - mainly doubling/halving the depth. I found that somehow the sensitivity setting had been changed. Once I reset it to its original (factory) setting it was fine. You can see how to do this in the user's manual. If you haven't got one you can download one from the NASA site.
