Clipper Depth fitting
stevebirch2002
11 Nov 2001
k up your larder - Malvern & Portsmouth
www.albinvega.co.uk
Anyone got any ideas or where to get platic tube the right size for internal fitting of the depth transducer. I feel very mean and dont want to pay £12 for a kit, plastic tube, oil and some filler! Ideas welcome.
Regards Steve Birch Vega "Southern Comfort" V1703
<hr width=100% size=1>Albin Vega "Southern Comfort" V1703
Jools_of_Top_Cat
16 Dec 2002
fairy liquid washing up bottle, cut to size ( make sure an adult is available), double sided sticky tape.
Or, drainpipe?
tupleware spaggetti holder, prolly in your loft or back of pan cupboard, never been used!
Or, cardboard, fiberglass around it and to bottom of hull, et voila, a ready made built in oil bath.
<hr width=100% size=1>Julian
<A target="_blank" HREF=http://www.topcatsail.co.uk/movies.html>Dolphin Movie From Top Cat</A>
Jools_of_Top_Cat
16 Dec 2002
Or,
Drill hole
push transducer through from outside with sik 292 - tighten nut
cheap and best readings
LORDNELSON
6 Sep 2002
West Sussex, England
That is exactly what I did two years ago and it has worked very well since then (the year before that I just stuck it down with a large blob of chewing gum to ensure I had got it in a suitable location; the chewing gum at the end of that season was showing signs of not liking the occasional drop of bilge water).
martinb
27 Apr 2002
Solent
I used the kit when I installed mine, but if I remember correctly, the kit contains a short length of domestic 1.25" sink waste pipe. I probably have a piece in the garage, or at work, if you want I will post you a length.
If I did it again, I would bond straight to the hull as my installation weeped and required occasional topping up with oil, despite carefull preparation of the area.
Martin
apollo
12 Sep 2003
Thames
Slap a big lump of petroleum jelly on the end of the transducer, then push it down and give it a twist into the hull at a dry flat place.... et voila.
No need for a pipe at all.
Fitted mine in Feb and went to Holland and back with no problems.
