Daydream believer
Op wants to release it quickly in the event of a problem. You cannot release a timber hitch quickly.Use a timber hitch
Look up ‘Tug boat hitch’ or ‘Lighterman’s hitch. If snugged up correctly, it CANNOT jamb.I maintain my position that almost any "quick release" knot pulled tight enough to shift that tree will be too tight to release quickly enough to do any good in an emergency. I'm also of the opinion that it's far too dangerous to attempt to attach anything to the tree until the water drops.
I'd agree another tree or two that size getting caught on that one is likely to be a problem. But I'm not certain the is EA's issue. Firstly I suspect (don't know the geography) the place most affected will be your power plant... So it just became your problem. EA are only interested in big floods with risk to life / political seats.It is the jamming of the tree that is causing much head scratching, and looking through the regulations. Its potential for snagging other trees leads us to think that Env Agncy has a potential flood creating problem and it is their job to clear it.
You know who owned the tree?We are also trying to see if the original owner of the tree is responsible for the damage, or whether it is an act of God. Being a foreseeable event (old tree, leaning over the river) , my view is that the owner should have felled and cleared it before it went walkies
Please cover the whole operation with cameras. £250 on you've been framed! You tube gold.Watch this space. I might borrow a reindeer or two after Christmas...
Have you considered consulting the Roya Society for Prevention of Cruelty to Reindeers if that is acceptable.?Watch this space. I might borrow a reindeer or two after Christmas...
That's an interesting knot, but I wouldn't call it quick release in the way a highwayman's hitch is. It's a good, secure knot that you can undo, but not in a second, by pulling the working endLook up ‘Tug boat hitch’ or ‘Lighterman’s hitch. If snugged up correctly, it CANNOT jamb.
Tugboat hitch - Tom Cunliffe
As is obvious with its name, it’s used to attach tugs to ships and they occasionally need to be undone in an emergency and under load. (i admit they always have an axe and balks of timber on deck but that’s in case the apprentice deck hand ties the tug boat hitch wrong. )
