Cleaning tips ..
Nostrodamus
7 Mar 2011
www.cygnus3.com
It is time to give the boat a good going over for next years cruising.
I have picked up some really good tips from the forum such as
1) Patio cleaner for teak
2) Toothpaste, and brasso for the plastic hatches
3) Lemon for cleaning the discoloured bow
Just wondered if anyone one had any more trade secrets, cleaning products or tips they had picked up along the way that may help bring the boat to the best I can make her.
Oxalic acid (powder) is brilliant at cleaning aged, yellowed fiberglass, you barely even have to scrub it and it brings things up like new again, and you can use it on teak too where it removes everything and brings that up like new too, its my new all purpose cleaning chemical !
Patio cleaner for teak ... but don't get the Patio furniture oil - it's somewhat slippery!! Made the first couple of sails quite interesting - then we sluiced through with seawater ....
Mind U - JFM doesn't like teakoil ... and that seems reasonable to me - so may try not doing it this year.
Any idea what it is called in France or how to get any?
cleaning
harpic limescale remover toilet cleaner will do all the jobs you have talked of and is easily available and cheap,i will leave the french traslation to someone else.Kieron
To keep the bowls in the heads sparkling white and clean, fill bowl with fresh water. Drop in two steradent tablets. Leave overnight. Flush and rinse. Then fill with fresh water to keep away nasty niffs.:D
I also someone mentioning Ottawa Oil or something although I have no idea what it does.
What is good on masts and cleats?
I got told by a rigger to clean lines in cold water as hot is no good for them.
Ciff Cream Lemon Cleaner
Ciff Cream Lemon Cleaner. Used on grey coach roof coaming sides to remove a few seasons stains. Brought the grey colour up very good and produced a nice even sheen without a high gloss that a cutting paste may produce. For my old GRP this is a better finish. Wash away with plenty of fresh water and wax as required. Also works well on hulls and gives a decent surface to polish up and then wax as appropriate. Old aluminium window frames, no problem, a good buff with Ciff produces a lustre that doesn't show off dings and dents like a polish.
A wonder product? Not quite, but for old boats it is appropriate. It is a very mild scouring agent, so best not to use it if you have a very high gloss finish surface.
http://www.unilever.co.uk/brands/homecarebrands/cif.aspx
I got some Oxalic Acid. They disguised it in France by calling it Acide Oxalique. Tricky buggers these French.
It is in crystal form so can anyone tell me the ratio to mix it.
I need to clean my hull.
About 100g a litre. Dissolves better in hot water. If any crystals precipitate out on cooling no prob.
It has a level of toxicity so best to avoid ingestion or skin contact.
Thank you.
Was just reading about it on another thread and getting it to stick to the hull when the boat i out.
