{151760}
That's the stuff.+1
I use white vinegar from my local international supermarket. It's basically non-brewed condiment without having the caramel and costs not much at all.
That's the stuff.+1
Eek! The others said overnight! I hope i don't go out and look for them tomorrow and they have disappeared?!
Dilute hydrochloric acid has no effect on brass or bronze, nor any common plastics and rubbers. It can attack some aluminium alloys but not others, so go carefully. I would have thought that 10 minutes immersion was ample, certainly is on my toilet.
The only thing still left on them is a bit of grease residue in the gear bits. I am inclined not to grease them when I put them back on. Im sure flexofold say not to. Just my neighbour who has the same prop does and I am too scared to do anything that he doesn't!
Brick cleaner won't do any harm. However I used kettle descaler as the blades where only lightly fouled.
Prepare yourself for a busy day following Flexofold's maintenance regime:
The only maintenance required is to keep the propeller clean.
The pivot pins and gears are water lubricated, however, adding waterproof grease to the moving parts will help the folding and unfolding.
http://www.flexofold.com/maintenance/
